the temperature gage goes up?
2011 BUICK LA CROSSE
172,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
JCHURCH76
When I drive my car the temperature gage goes up. When I stop it goes back down. It's not really overheating. I've used a temp gun and it's where it's supposed to be. There's no pressure in the hose. The check engine light is on as well
Feb 13, 2026 at 7:30 AM
STEVE W.
  • 15,344 POSTS
First thing, scan it to get the codes it is storing. That will give you a starting point. However that could be a couple things, one being a stuck open thermostat, that will commonly set a P0128 because the engine doesn't warm up as fast as it should. The other reason could be the cooling fans stuck on, Do you hear a loud rushing sound when the engine is running but setting still? Many parts stores will scan the codes for free. Write down the codes or scan it yourself with a code reader and post them here. You don't need a fancy tool for that, you can get one like the Autel AL329 series at Wal-Mart that works pretty well for powertrain codes.
Feb 13, 2026 at 11:51 AM
