temperature sensor
4,000 MILES • 3.5L • 6 CYL • TURBO • 4WD • AUTOMATIC
NYN8TIVE
Removed fuse box cover to install accessories. had a hard time putting it back on but finally got it. started truck and temperature gauge spiked!! what happened?
Sep 8, 2020 at 9:31 PM
Good morning,
What accessory did you install and what did you attach the wiring?
You apparently got into some circuit.
Sep 8, 2020 at 9:42 PM
NYN8TIVE
Fog lights. Hooked up to upfitter switches.
Sep 8, 2020 at 9:52 PM
I would remove the fuse box again and make sure you did not crush any wires or connectors that are not disturbed.
Sep 8, 2020 at 10:00 PM
