Temperature gauge suddenly stopped working
147,000 MILES • 3.8L • V6 • FWD • AUTOMATIC
CHER GOULET
Temperature gauge suddenly stopped working on commute home. Gauge moves slightly when car is started, but does not move after that. Fan squealed when car was started a couple of times before this happened, and each time I had to turn the car off and back on three times before it stopped. Fan also continues to run for a few minutes after the car is turned off. Sensor in the radiator went a few years ago, but due to the age of the car, it was not worth replacing the radiator to fix it. I keep an eye on engine Temperature gauge daily, and regularly check coolant reservoir. Engine has not been overheating at all.
first question, how do I get this fixed?
second question, can I still drive the car to work and home (110 km) until I can arrange to drop it off at a mechanic? Kind of need to be at work tomorrow, so I am sort of up the creek.
Dec 29, 2016 at 10:10 AM
SATURNTECH9
  • 30,868 POSTS
That should have a single belt on that engine most likely you have a failing serpentine belt tensor.If it's stealing that much the belt tensor could fail at anytime and leave you stranded or cause a overheating condition.The coolant temp sensor should be screwed into engine in that engine not the radiator.Sounds like a bad coolant temp sensor or a rodent might have chewed the wires etc.you wouldn't know if the engine was overheating with the temp gauge inop while you were driving.
Dec 31, 2016 at 6:48 PM
