Temperature gauge is running higher than normal
140,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
CINDER4062
  • 36 POSTS
I trying to find out why temperature gauge is trying to run above normal. I changed my thermostat and the only thing I can think of next is my water pump. Would that cause the issue? I trying to prevent my vehicle from having an overheating episode. All suggestions are welcome. Thank you in advance for your timely response.
Apr 29, 2018 at 10:48 AM
CJ MEDEVAC
  • 11,000 POSTS
The thermostat is a good and inexpensive place to start.
Fan working?
Other considerations might be old, wrong mix of coolant,
clogged bent radiator fins,
Twelve year old radiator scaled up inside, possibly verify it is cooling ability with an infrared temperature gun, Some are as cheap as $30.00, see if a shop will check it in the parking lot. (flush, if possible or replace the radiator)
Old squishy radiator hoses sucking flat.
I looked at a auto store site, the water pump they show has a plastic impeller (first picture below) Another brand may be metal?
Here is more information from "repair guides", top right of our pages.
https://www.2carpros.com/articles/symptoms-of-an-overheating-engine
Not trying to scare you, but plastic and water pump does not seem to fit together in my book. First picture below is the one I got at the auto store site. The rest are failures from other vehicles, some are missing a fin, slipping on the shaft, others are total fails. Unfortunately, this would require removal to inspect it.
Site unseen, my Lottery guess is the radiator internally.
Sometimes it might just be a defective temperature sending unit.
Let us know how your investigation goes, check it out well before you start slinging in unneeded parts!
The Medic
Apr 29, 2018 at 1:27 PM
STEVE W.
  • 15,418 POSTS
Define "hotter than normal". Most modern engines run hotter than older engines, 210°F - 215°F is normal operating temperature these days. If it is running higher than that I would start by checking the fan clutch. These can fail and cause both over cooling (if they fail and stay on) or overheating if they fail and do not engage as needed.
If the fan clutch is okay then you may have a partially plugged radiator.
However, I would use a mechanical temperature device first to verify that it is actually running hotter than it should.
Apr 29, 2018 at 1:52 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
replace the Viscous Fan Drive.
Apr 30, 2018 at 12:47 AM
