Temp gauge goes to hot then occasionally goes to normal then goes back up
76,000 MILES • 3.5L • V6 • FWD • AUTOMATIC
RGOTO
Temp gauge goes to hot stays there for a while then drops to about midway then goes back up to hot for a while. Goes back down for a short while then goes back up. Coolant reservoir is full.
Just had water pump replaced. Ac seems to stop working when gauge goes to hot.
Heat seems to be working fine. No performance issues. No warning lights. No visible leaks. Radiator fan turns on.
Aug 18, 2015 at 7:31 PM
DOCHAGERTY
  • 9,606 POSTS
I request some more information please.
The repairs were made and the car was released, and this is when the issue began, yes?
If so, have you been in contact with the agency that repaired the car? If so, what did they recommend ?
Aug 19, 2015 at 12:27 AM
RGOTO
Repair was done month and a half to two months ago. No issues till now. Having him take a look again today.
Aug 19, 2015 at 1:35 AM
DOCHAGERTY
  • 9,606 POSTS
I am hopeful for a favorable outcome mate
Aug 20, 2015 at 1:39 AM
RGOTO
He couldnt figure it out. Believes not water pump or thermostat. Any ideas or tests i could do or suggest??
Aug 20, 2015 at 2:38 AM
DOCHAGERTY
  • 9,606 POSTS
An eight year old cooling system could have a radiator that simply cannot dissipate excess heat, this could be caused by failure to regularly flush the cooling system.
The complete history is unknown and I am not privy to the ability level or competence of the repairing facility you employed.
I would begin this diagnosis with a personal inspection of all components and a review of the history of service.
Aug 20, 2015 at 3:56 AM
