Temperature gauge not reaching halfway mark, no heat in cabin?
232,282 MILES • V6 • 2WD • AUTOMATIC
GREYSDAD86
Replaced the Temperature Sensor and thermostat, blend door actuator. Temperature gauge still reading cold goes up some then comes down slightly. No heat in the cabin.
Jan 20, 2025 at 12:36 AM
BORIS K
  • 836 POSTS
It sounds like there might by some air trapped in the cooling system.
Suggest trying bleed the system properly.
A good video:
https://youtu.be/oqcHzbcxP5E?si=YROYpStDQRf_Z-Si
A guide:
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Cheers, Boris
Jan 20, 2025 at 1:32 AM
GREYSDAD86
Thanks Sir.
Greatly appreciated.
Jan 20, 2025 at 2:37 AM
  • 55,649 POSTS
BORIS K is one of our best! Use 2CarPros anytime we are here to help.
Jan 22, 2025 at 12:30 AM
