Where is the TCU located?
105,000 MILES • V10 • 4WD • AUTOMATIC
DIVIDES
  • 903 POSTS
If you can tell me where the TCU is located please.
Sep 6, 2021 at 12:53 AM
  • 110,251 POSTS
Are you referring to the Mechatronics control unit? That is what controls the transmission. If that is correct, it is located in the transmission (valve body).
See pic 1 below. I highlighted the control unit.
Let me know if that helps.
See pic below.
Sep 6, 2021 at 12:22 PM
When you say TCU, I assume you mean the transmission control unit? If so, they call this a TCM which is actually the mechatronic unit which is basically the valve body inside the oil pan.
I am attaching the info below on this unit so please take a look at it and let me know if you have questions on this.
Thanks
Sep 6, 2021 at 12:23 PM
DIVIDES
  • 903 POSTS
Thanks to you both. So this car has no external TCM just like an ECU to the motor?
Sep 6, 2021 at 12:48 PM
  • 110,251 POSTS
That is correct. The module is the mechatronic unit. By the way, great car!!!
Sep 6, 2021 at 2:19 PM
