tcs light and hesitate starting after getting emission test
160,000 MILES • 3.2L • AUTOMATIC
SPWEH1
car was running fine until i had to get the emission test (passed). had to get it to change title. then car hesitated to start and dashboard lights flashing (TCS) light stays on for a few minutes then goes off. car doesn't seem to idle as well. what is up? please help?
Feb 11, 2015 at 9:13 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge first auto parts rent it. then clean throttle plate on both sides.
Feb 12, 2015 at 1:51 AM
  • 55,594 POSTS
We need to run the codes, this guide can help.
It sounds like when the car was getting inspected one of the wheel speed sensor wirings got damaged. I would raise the car up to inspect here are the location of the wheel speed sensors. Also check out this video for the idling problem,
https://youtu.be/XMB16Gg-qNg?si=vdhChI_SWIDXz6cW
Jul 1, 2024 at 11:30 AM
