TCL off light
130,000 MILES
HPBRAT
After driving for about 10 -20 minutes, the TCL off light comes on. What causes this and how is it fixed?
Apr 19, 2013 at 7:23 AM
This means there is a problem with the ABS and traction control which will be one of the wheel speed sensors mostly likely but to be sure lets run the codes. Check out the video below.
https://youtu.be/rTtAnsOlZU4
Please run down this guide and report back
Cheers
Apr 19, 2013 at 8:10 AM
SHARIQ
I had a right front ABS wheel speed sensor out
Oct 30, 2018 at 7:18 AM
JGONZALEZ714
  • 6 POSTS
Do you think it can be the ABS's sensors. they have four, one in each wheel, right?
Oct 30, 2018 at 7:18 AM (Merged)
HMAC300
  • 48,601 POSTS
yes, it can be anything until it is scanned you do not know where to start.
  • 55,746 POSTS
Hey Jgonzalez714,
Yes it could be one of the sensors here is a guide that will show you how to test them.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Please let us know what you find so it will help others.
Best, Ken
JGONZALEZ714
  • 6 POSTS
Hello again. I have another problem or concern. I arrow of the temperature is going up a little higher than usual. I check the coolant tank, and it is normal. What can be the problem.
HMAC300
  • 48,601 POSTS
this can be anything if goes to hot then have it checked for a head gasket problem. in the future POST your questions not as a reply .
JGONZALEZ714
  • 6 POSTS
I am sorry for not responding promptly, If it is not head gasket, would be the temperature sensor. Thanks
CUTESTUFF59
  • 12 POSTS
While driving the TCL off light came on. What does this mean?
  • 31,937 POSTS
this is the traction control system which is now off. You may have a problem with a wheel speed sensor, this will often affect the ABS as well. Here is a video to help you see which wheels ensor is out.
if you don't have a scanner here is a guide that will show you how to test the wheel speeds sensors
Please let us know what you find.
Cheers
HMAC300
  • 48,601 POSTS
I kind of doubt it if it's overheating it wouldint be a sensor scanning that was done would have shown it.
JGONZALEZ714
  • 6 POSTS
Hello HMCAC 300. Several months ago I contacted you about the TCL lights coming on and off. I continue to have the same problem, and now it turns and car on and off, even when I am driving. So, yesterday I scan the car for possible problems again. This is the result and I need your help, please. This the code P1102 - Traction Control Ventilation Solenoid Circuit, which indicates that with the engine running for a predetermined period of time the PCM detected the T/C ventilation solenoid motor failed the Comprehensive Component Monitor rationality test.
The Code went further to tell me that: The Traction Control Diagnostic Trouble Code 72 or 73, "Vacuum/Ventilation Control Solenoid Circuit System"may set and the TCL light may come on, due to excessive ignition signal interference affecting the voltage in the TCL solenoid valve harness. This may also cause MFI DTC P1101 or P1102 to set in the PCM. To eliminate this condition, install a noise filter in the wiring harness at the distributor connector.
JGONZALEZ714
  • 6 POSTS
And I forgot to mention that the engine light has not turn on, just the TCL light. Thank you very much HMCAC 300
HMAC300
  • 48,601 POSTS
check what is in the pic for cause but it may be a bad pcm also check green stripe vacuum hose leading to it for being broken or leaking both the solenoid and valve are at back left rear of engine compartment both of these are for the engine running not the TCL a mechanic has to scan for codes for that an auto parts scanner will not pic up any TCL codes. also in Future post this question not as a reply thanks.
JGONZALEZ714
  • 6 POSTS
Thank you HMAC 300. So you do not think that I should install the Noise Filter first. That I should check your recommendation first. Sir, I am so confused, I had spend a lot of money, different mechanic had tell me different things. And the problem remain the same. Again thank you Sir
HMAC300
  • 48,601 POSTS
check what I sent to you see of solenoid gets power too I will not be here next few days repost question
