Where is the TCC control solenoid valve control circuit low voltage?
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
TLB76
Is it in the transmission or the outside, is it easy for me to do or get a mechanic to change it?
Sep 24, 2023 at 10:13 AM
  • 110,251 POSTS
The part is in the transmission. To access it, the side cover (valve body cover) needs to be removed.
If you look below, pic 1 shows the location. The remaining pictures are the directions for the removal and installation of the part.
The last two pictures are for resetting the transmission adaptive functions.
joe
Sep 24, 2023 at 1:51 PM
TLB76
Okay, thank you so much.
Sep 24, 2023 at 2:17 PM
  • 110,251 POSTS
You are very welcome. If you have a chance, let me know if this resolves the issues. Also, let me know if you have other questions.
Sep 25, 2023 at 6:04 AM
TLB76
I sure will, Thanks again
Sep 25, 2023 at 6:39 AM
