Transfer case plug diagram
136,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
PRATTMAN
I am in need of a transfer case actuator plug wiring diagram so I know where the wires go in the connector.
Oct 26, 2019 at 7:00 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is a wire checking tutorial in case you need to view:
I've attached the transfer case wiring diagram below as you requested. I've split it in half to make it larger in size by making it 2 photos. Hope this helps and thanks for using 2CarPros.
Danny-
Oct 26, 2019 at 11:36 AM
