Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Cobalt
General
Noises
Tap
Tapping when car is started, stops after a few seconds
2009 CHEVROLET COBALT
71,000 MILES
CORINNE KOWALSKEY
MEMBER
1 POST
Tapping when engine started. Stops after few seconds. Happened two months ago one time. Never again until today.
Jan 5, 2018 at 5:44 AM
Experienced Mechanic
Good morning.
If it is a valve train noise, it could be a tuck lifter. Using a product called sea foam to try and break down the varnish in the lifters.
the other possibility is the lower end that has the bearings. If there is excessive clearance or the oil pump is weak it will also cause the issue.
Jan 5, 2018 at 8:47 PM
Add image or video
Ask a new question
Check engine light
Engine won't start
