To get you started, here is a link that explains in general how one is replaced. You can use this to help guide you:
I'm not sure if it is the blend door actuator for the left or right, so I attached directions for both. The torque specs are included.
Also, when you say drain plug, I still don't know which one you are referring to. Let me know.
Take care and let me know if this helps.
Images (Click to enlarge)
Aug 16, 2022 at 2:16 PM
