Tap into keyed (switched) power source
210,000 MILES • 4.0L • 6 CYL • 4WD • MANUAL
T2TRUE
I need to tap into a keyed power source for an external wiring harness. I have not been able to find a good solution under the hood. Where should I look to find a good power source for when key in run position?
Thanks
Oct 19, 2017 at 5:36 AM
  • 31,937 POSTS
Probe back of the fuse box for a switched power supply. check the fuse information in your owners manual. you may have a spare fuse for such a purpose installed.
Oct 19, 2017 at 4:31 PM
T2TRUE
Please clarify what "probe back of the fuse box" means.
Oct 19, 2017 at 11:08 PM
  • 55,732 POSTS
Use a test light to check for power when the key is in the on position. How many amps are you looking for with the accessory you are using?
Please let us know
Cheers, Ken
Oct 28, 2017 at 12:44 PM
