No bolt missing there either. GM makes many of these parts to fit into multiple vehicles and applications. They drill and tap all the holes simply because it's faster and easier and makes it so that you can add or subtract the various parts and brackets to fit the vehicle and options it has without needing special parts.
That way they don't have an engine block that can only be used in a 2001 Chevy P/U without AC but with power steering and an automatic transmission. But won't fit the same block if used with a manual transmission.
Instead the same block can be used in the entire truck and car line and everything bolts up as needed. Doesn't matter if it's an automatic or a stick shift or if it has a hydraulic or cable clutch. The holes are already there.
In this case that hole isn't used with an automatic transmission. It's just there. Start looking and you will also find many more holes and wires and even brackets and studs that are empty or lead to nothing. It's just cheaper and faster to make the parts that way at the factory to fit all the possible configurations.
For instance that same 4.3 block is used in the P/Us, Vans, S-Series, Boats, and industrial applications. Same thing with the transmissions and other parts.
Nov 26, 2017 at 3:02 AM
