How to drain the reservoir tank
1999 SATURN SL2
1,361,500 MILES • 4 CYL • 2WD • MANUAL
LA.VERO
  • 43 POSTS
I need to drain the reservoir tank to add antifreeze. Does any one know how to do it that can explain to me please?
Nov 9, 2017 at 3:15 AM
CJ MEDEVAC
  • 11,004 POSTS
This might be an easy way.
Be sure to remove the vac's filter.
Use a piece of fuel line or vacuum line (instead of the steel brake line in my picture).
Duct tape/etc., the smaller line inside the hose, seal it off good.
Let us know how it goes.
The Medic
Nov 9, 2017 at 10:30 AM
STEVE W.
  • 15,357 POSTS
What does the tank currently have in it?
If it is only water then you will need to drain the entire cooling system and then refill with 50/50 coolant mix. Just draining the reservoir will not be enough to protect the system. If it already has actual anti-freeze in it you need to just add more Dex-Cool.
Nov 9, 2017 at 11:07 PM
