Take off strater
19,006 MILES
LARUNG58
How to remove the strater
Jan 17, 2016 at 4:50 AM
PACO8224
  • 117 POSTS
Disconnect negative terminal on battery. Raise or lift car on passenger side, the starter is located between engine and transmission. Remove the power wire with a 13 mm, and the negative wire with 10mm, then remove starter bolts 3 of them they should be 13 mm. Aswell
Jan 17, 2016 at 5:04 AM
