why is car smoking light blue smoke mostly at idle when it is not useing any oil on dipstick
Apr 21, 2013 at 10:18 AM
✓Experienced Mechanic
Blue smoke is oil burning, check spark plugs for ash deposits a comp test or a leak down test will give a good indication as to ring condition.
Apr 21, 2013 at 7:45 PM
CYCLEPOPS
MEMBER
did com test and leak down 180 -183 all ,no leak off no black on plugs,all rubber around valves looks great [as it should ] .shows some oil in intake but can not figure how it's getting there took hoses off vacum sys , drove 40 mi still smoking same. thanks for any help u can give me terry
Apr 21, 2013 at 10:02 PM
CYCLEPOPS
MEMBER
cold i have a cracked [ broken oil [ ring and leak down still be good
Apr 21, 2013 at 10:21 PM
CYCLEPOPS
MEMBER
and i don't understand what o-ring ?????
Apr 21, 2013 at 10:23 PM
engine may be breathing heavy, due to blow by constant blue smoke is oil burning, either from faulty rings or worn valve guides and valve guide seals.
Apr 22, 2013 at 7:18 AM
CYCLEPOPS
MEMBER
ok thanks
Apr 23, 2013 at 9:31 AM
closing thread, you can re post if you have further questions, do not respond to this message.
