Electrical issues and it will not go into AWD
124,000 MILES • V8 • 4WD • AUTOMATIC
LISH1990
I have just recently purchased the vehicle listed above RT model. The running lights won't work. I have changed a fuse and a relay and they keep going out. The horn doesn't work as well and there is no interior lights either. I cannot put it in awd because it grinds and doesn't move. It will drive in 4high. Does anyone have any answers please.
Oct 4, 2019 at 10:57 AM
  • 110,248 POSTS
Welcome to 2CarPros.
It sounds like a few different issues. Which fuse keeps blowing? Also, when you shift to awd, are you doing it while parked and in neutral?
I will say this. These vehicles have what is called a TIPM. That stands for totally integrated power module. From experience, I have found that most all electrical issues are related to the connection pins in the plugs. There are several plugs which attach to it with many pins. What seems to happen is they corrode, break, or for other reasons lose connection.
Let me know which fuses are the issue and if anything when shifting to 4wd works.
Oct 6, 2019 at 12:37 PM
