Hello Kat,
It sounds to me like you could have a bad ground connection. I have uploaded the wiring diagram for that circuit it shows the grounds and there locations. Rotate them in your image program I had to put them sideways to get it to fit at a good readable size. Do you have a test light? If you don't see an obvious broken ground wire we will have to do some tests to isolate which component isn't working properly.
Let me know,
Tom
Images (Click to enlarge)
Jul 25, 2020 at 1:32 PM
