Tailgate lining removal
120,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
WUNING
The tailgate latch loosen and need to remove the lining to tight it up.
Jul 16, 2018 at 12:51 AM
  • 110,248 POSTS
I have attached two pictures for your review. The first picture is of the hatch trim panel and the second contains the steps to remove the unit. These pictures correlate together so you can use the picture to locate components listed in the directions.
Once you get the panel off, you will see the latch assembly. Picture 3 is the latch.
I hope this helps. Let me know if you have other questions.
Jul 16, 2018 at 1:11 PM
WUNING
Hi Joe,
Thanks for the information. I end up removed the 2 x B clips that allow me to peer back the lining enough to tighten the screws on both side of the latch.
Jul 17, 2018 at 10:16 AM
  • 110,248 POSTS
That was a good idea. Glad you got it fixed. Let us know if you have questions in the future.
Jul 17, 2018 at 12:40 PM
