Tailgate glass window will not open
75,000 MILES • 3.7L • V6 • 4WD • AUTOMATIC
KELTO981
The tailgate glass will not release with the push button on the handle or with the key fob. Normally when you press the key fob you will here a "click" and it pops open, this does not happen with either way. Also, sinc ethis problem started, the interior lights will stay on and on the dash it shows that the rear gate is open ( will say this when the gate or the window is open). I've checked all the wire connections and fuses with no luck.
Feb 22, 2016 at 11:32 PM
  • 55,561 POSTS
If the latch actuator fails it will cause this problem, can you access it from inside the car? you will need to remove the inner panel.
Feb 29, 2016 at 2:37 AM
