tail lite,s turn signals & brake lites
95,000 MILES • 3.4L • V6 • FWD • AUTOMATIC
WHOLLIE1969
both the REAR turn signals as well as REAR brake lite's don't work . checked all fuse's , checked all bulb's , all ok .
Oct 4, 2015 at 1:01 AM
HMAC300
  • 48,601 POSTS
check to see if power is coming through the t/s switch it's the lt blue and dark blue wires.also check flasher under lh side of dash by steering wheel . if center mount brake light does not work check white wire from brake light switch as it may be bad.
Oct 4, 2015 at 1:16 AM
