The taillights stay on when truck is on or off?
400,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
JURZEI
Yesterday the passenger park light was also on, and today it's now taillights and park lights. We know it's not the light switch or fuses.
Dec 20, 2022 at 10:04 PM
  • 110,248 POSTS
Park lamps use a driver in the front control module that is part of the TIPM (totally integrated power module). Power from the module is sent to a parking lamp relay and then through a fuse to the lamps.
I attached the wiring schematic below, so you have a reference. Here is what I want you to try. Disconnect the battery for about ten minutes and see if it resets the control module.
Let me know if that takes care of the issue.
joe
Dec 21, 2022 at 1:54 PM
