Tail lights/ parking lights not coming on
125,000 MILES
JNEUB60
1990 Dodge Spirit 4 cylinder. Parking lights / tail lights do not work. Bulbs are fine and fuses are fine. Is there a relay that could cause this problem and if so, is it under the hood and if so, how do I tell which one it is? Headlights, backup lights and turn signals all work fine.
Nov 3, 2013 at 7:09 AM
  • 110,251 POSTS
Do the brake lights work?
Nov 3, 2013 at 10:22 AM
JNEUB60
Yes, brakes light work
Nov 3, 2013 at 9:46 PM
  • 110,251 POSTS
Have you tried tracing the wiring to see if you can locate where the power is lost? Is there power at the fuse?
Nov 4, 2013 at 12:34 AM
JNEUB60
Yes, there is power at the fuse. I have done some tracing but was trying to save some time if it was just a matter of a bad relay. I just don't know if this circuit has a relay
Nov 4, 2013 at 2:09 AM
  • 110,251 POSTS
I don't believe there is a relay for the lights.
Nov 4, 2013 at 11:45 AM
