Taillights not working?
78,000 MILES • 4 CYL • 4WD • AUTOMATIC
DAVIDDEBRO
Brake lights work but not running lights.
Jul 25, 2018 at 3:37 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
First question. Have you checked the fuse in in under hood fuse/relay box?
Danny-
Jul 26, 2018 at 11:13 PM
DAVIDDEBRO
Which fuse? None are listed for taillights or running lights? I looked at both fuse box labels for inside car and under hood.
Jul 27, 2018 at 2:26 AM
DANNY L
  • 5,648 POSTS
Hello again.
It is in the fuse box located under dash and the fuse is #15. Picture attached. Hope this helps.
Danny-
Jul 27, 2018 at 2:50 AM
DAVIDDEBRO
Thanks, I will try that.
Jul 27, 2018 at 3:34 AM
DANNY L
  • 5,648 POSTS
You are welcome.
Let me know if you have any other question and thanks for using 2CarPros.
Danny-
Jul 27, 2018 at 4:41 AM
DAVIDDEBRO
That was it, fuse #15. Now to see if it blows again.
Jul 27, 2018 at 6:05 AM
DANNY L
  • 5,648 POSTS
Hello again.
Glad to help. Let us know what happens and thanks again for using 2CarPros.
Danny-
Jul 27, 2018 at 6:09 AM
KARENLEA
We bought this CRV about a month ago and had a base plate and plug mounted to enable towing behind our RV. Now the tail lights on the CRV do not work. The fuse is not blown; seemingly, all other lights are functioning normally, including dash lights. Can you help?
Aug 4, 2020 at 5:28 AM (Merged)
DOCHAGERTY
  • 9,606 POSTS
The only help that I can send from cyberspace is advice. Return to the installing technician and have them recheck their work. Other than the possibility that both the tail light bulbs require replacement, I am at a loss.
KARENLEA
Thank you for your reply! I knew it was a long shot, and I did find a schematic that showed where the actual fuse is for the tail lights. Our owners manual pointed to the fuse box under the hood, but it was actually #15--located inside the car. It is actually in front of the relay.
DOCHAGERTY
  • 9,606 POSTS
Well.. sometimes we take those longshots here at 2CarPros!
WHEWETT63
My rear passenger side brake and running lights not working. Replaced bulbs but still nothing, but when i lock the doors they blink on as they should. i do not understand. thanks for any help.
  • 55,743 POSTS
You must be loosing power somewhere. Here are the wiring diagrams for the car tail and brake lights so you can see how the system works along with a guide to show you how to test for power.
Start by checking the fuses
Also check the connector at the tail light lens
The running lights are wired together so it makes me thing the problem is at the lens
Check out the diagrams (Below)
Cheers, Ken
WHEWETT63
Hi Ken,Thanks so much for responding back.Will be out of town this weekend soon as i return i will check it all out and get back to you..Thanks so much and have a great weekend...
  • 55,743 POSTS
It looks like i forgot the fuse panel diagrams so I updated the post. Please let me know what happens.
DVCAIN
when the brake pedal is pressed the right rear lights work properly, but on the left side the taillight filament on the brake/tail light bulb comes on. I checked the light socket with a test light and have power to both contacts when the brake pedal is pressed but only the taillight filament of the bulb comes on. I also checked the bulb and it works when I put power to the brake/turn signal filament.
That is interesting because I suspect the issue is the splice inside the assembly. It is interesting because I have not seen that specific failure before but it appears this would be the issue if you have power at both connectors and the bulb works.
Let me know if I am understanding this correctly but it would make sense if this assembly has this splice inside of it.
CIRCA55
Dash lights and tail lights do not work until car warms up. E-Brake lamp is lit at start, but turns off at warm up.
Aug 4, 2020 at 5:29 AM (Merged)
KHLOW2008
  • 41,812 POSTS
Check the brake fluid level.
The taillights and dash lights are in the same circuit and are straightforward circuits.
Check the switch, fuses and wirings for loose connections.
CIRCA55
Brake fluid level is good.
The lights all turn on/off simultaneously.
KHLOW2008
  • 41,812 POSTS
There could be a loose ground circuit somewhere.
CIRCA55
How would loose ground be affected by engine temp, as opposed to something like road bumps?
KHLOW2008
  • 41,812 POSTS
It is not engine temperature that is causing the lights to turn off if my guess is correct and both the systems have nothing to do with the engine.
Poor ground or loose connections would be affected by heat and resistance due to currecnt passing through them.
