tail lights, fuse box malfunction
105,000 MILES
NICKP92
I accidentally put the wrong fuse in place of the one that should have been in there I also installed a had unit and amp, it kept blowing fuses and I got em mixed up changing them all the time and now only some dash lights come on but no tail lights what can I do to get the tails working again?
May 19, 2013 at 12:57 AM
CARADIODOC
  • 34,415 POSTS
Disconnect the noise makers, then see if the fuses blow. If they do not, look at how you have those toys wired in and to which fuses you connected them to. Besides destroying your hearing and irritating other people, aftermarket amps draw a real lot of current and will blow fuses that are too small. You generally need to run fused power wires for amps right to the battery.
May 19, 2013 at 4:24 AM
