Tail lights and blinkers
180,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
EDGOLFER
Yesterday the blinkers and brake lights went out, this morning there was a clicking noise under the dash and the battery was drained?
What happened?
Oct 18, 2018 at 2:38 AM
  • 55,746 POSTS
It sounds like your battery is no good but to be sure charge the battery and then load test it. Here are two guides to help get the car started to see if the alternator is changing:
https://youtu.be/a9Ycibu9cwY
and
https://youtu.be/Z-p4dMJUpUw
If the battery is no good here is a guide to help you change it.
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Cheers, Ken
Oct 19, 2018 at 5:39 AM
