Tail Lights and brake lights are all out
92,000 MILES • 4 CYL • 2WD • AUTOMATIC
CINDYMACK
I was driving tonight, and was told I have no brake lights, and my tail lights are out
Sep 8, 2015 at 10:52 AM
  • 110,248 POSTS
It sounds like you may have a fuse out here is a guide to help you check
Here is a wiring diagrams so you can see how the system works. If the fuses are okay check the system grounds I have seen the TIPM go bad which will also cause the issue.
Please run down these guides and diagrams and report back
Cheers
Sep 8, 2015 at 11:59 AM
CINDYMACK
Thank You so much... I really Appreciate it !
Sep 8, 2015 at 12:08 PM
  • 110,248 POSTS
Let me know what you find.
Sep 8, 2015 at 12:34 PM
CINDYMACK
I checked the easy stuff then gave up I had to take it to the shop where they replace the TIPM. Its cost me $389.00 Thanks for your help though I love this site.
Sep 8, 2015 at 12:40 PM
