This can be the headlight switch or the taillight relay, here is the location of the relay so you can swap it out which will be easy. Also, here is a guide to go over that can help as well:
Images (Click to enlarge)
Apr 30, 2024 at 4:36 AM
DANIEL HYATT
MEMBER
how do i change the relay? it's wires not a plug.
May 1, 2024 at 3:03 AM
✓Experienced Mechanic
Can you upload an images of what you are seeing? The relay should just pull out from the relay box.
May 2, 2024 at 1:50 AM
DANIEL HYATT
MEMBER
unsure i have the right location. what i found that looks like the images was behind the glove box under the dash.
May 2, 2024 at 1:55 AM
The relay should be on the backside of the fuse panel on the right side of the dash. Let me know, upload images please so I can confirm you have the correct relay.
