Tail lights keep going out
250,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
JAMES LYON
My tail and dash lights keep going out. changed fuse one time it worked, did it again changed fuse it did not work.
Jan 28, 2018 at 3:28 AM
  • 55,749 POSTS
You must be loosing power somewhere are have a shorted wire lets run this test to see whats going on. It sounds like you have a headlight switch that may have gone out.
Below are the wiring diagrams for the running lights.
Check out the diagrams (below).
Cheers, Ken
Jan 30, 2018 at 3:02 AM
JAMES LYON
Thank you I will try that. I have priced the switch if that is what it is.
Jan 30, 2018 at 2:24 PM
