Tail light replacement/swap
1993 JEEP CHEROKEE
170,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
ROSALIE MCCANN
My vehicle listed above (Country) tail light socket/wiring assembly has rusted away from the bulbs. Can I swap that with a wiring assembly from a 1998 Jeep Cherokee Sport?
Nov 17, 2018 at 1:06 PM
  • 110,244 POSTS
As long as it uses the same type bulb and has the same number of wires, you should be fine. I believe they all mounted the same into the lens. However, confirm that before you start working on it.
Let me know if you need anything.
Nov 18, 2018 at 10:29 AM
