Tail light removal
88,000 MILES
JIMH3109
I'm tracking down a trunk leak. I want to remove the center tail light to check and/or replace the gasket. Got the bulb bar out. It was held on with phillips screws. the mounting bracket for it which also holds on the tail light lens is held on by two (?) somethings. They're recessed and you can't really see them. I've tried several small Alen wrenches and screwdrivers. What kind of screws are those and how do you remover them?
Thanks,
Jim
May 29, 2013 at 5:12 AM
DOCHAGERTY
  • 9,606 POSTS
Which one Jim?
May 29, 2013 at 1:14 PM
JIMH3109
The #7 screws. They're Filister head screws which means they have a thick head, but it doesn't tell what kind of Filister, i.e. slot, phillips, etc. That would tell me what kind of tool I'll need to take them out. Thanks for the diagram.
May 30, 2013 at 12:21 AM
DOCHAGERTY
  • 9,606 POSTS
Torx perhaps, like a T10
May 30, 2013 at 2:53 AM
JIMH3109
Excellent!!! Thanks a lot. I had a set of Torx that fit in my socket but the socket was too big to reach down the tube to the screw. My neighbor works on electronics and had a set of torx screwdrivers and it fit right in. You put me on the right track. Thanks.
May 30, 2013 at 3:11 AM
DOCHAGERTY
  • 9,606 POSTS
A dab of clear silicone to seal it up too Jim
May 31, 2013 at 12:59 AM
