Tail light problem
152,000 MILES • V6 • 2WD • AUTOMATIC
MARVIN_MCNEIL11
Park lamp out reading on the dashboard.
Oct 30, 2018 at 7:33 AM
  • 110,248 POSTS
That indicates one of the light bulbs is burned out on the exterior of the vehicle. First, have a helper watch the rear and front signal and marker lights to confirm which one is bad. It could be a brake light, turn signal (which will cause the flasher to double time) back up light.
Once you determine which bulb is bad, simply replace it. Here are a couple links that show in general how different bulbs are replaced:
https://www.2carpros.com/articles/turn-signal-bulb-replacement
https://www.2carpros.com/articles/reverse-light-bulb-replacement
https://www.2carpros.com/articles/brake-lights-not-working
Oct 30, 2018 at 12:41 PM
