Tail light problem
130,000 MILES • 4.8L • V8 • 4WD • AUTOMATIC
JOSHUA WILLIS
I recently purchased some aftermarket led tail lights and when I installed them the driver side does not work. I have checked my fuses and looked for shorts in my wires but nothing is wrong. Any advice?
Apr 22, 2016 at 1:53 AM
HMAC300
  • 48,601 POSTS
check the ground to it or it may just not be compatible with your vehicle which is on the lh rear frame rail. also check the junction connection on rear frame rail and put some dielectric grease at that connection. if regular bulb works then it's probably not compatible.
Apr 22, 2016 at 2:44 AM
