Tail light not working and audio button not illuminating
16,000 MILES • 6 CYL • 2WD • AUTOMATIC
FJKHAN24
  • 9 POSTS
Tail light is not working and audio button that has the navi/phone/info/audio button is not illuminating. Any help in diagnosing the fuse please?
Feb 7, 2019 at 2:02 AM
  • 55,691 POSTS
It sounds like the tail light relay or number a22 fuse is out but to be sure lets run these tests on the fuse and relay. Here is the wiring diagrams for the tail lights so you can see how the system works with the relay and fuse location:
and
Check out the diagrams (below). Please let us know what you find. We are interested to see what it is. The fuse panel is in the left rear of the engine compartment.
Feb 8, 2019 at 5:51 AM
FJKHAN24
  • 9 POSTS
Diagram you sent is for 2017 Acura RDX, are they similar. They are total of four fuse boxes, which one does this corresponds to, and what should I look for?
Feb 8, 2019 at 6:47 AM
  • 55,691 POSTS
My bad, I updated the post above to include the correct vehicle and all the relay and fuse locations so you can keep this page as a reference to any electrical problem you might be having. Check the post above for the updated information. Please let us know what you find. We are interested to see what it is.
Feb 9, 2019 at 10:01 AM
FJKHAN24
  • 9 POSTS
Can you direct me to the fuse or relay I should be checking? I’m not a electrical guy, have hard time reading it.
Feb 10, 2019 at 1:31 AM
  • 55,691 POSTS
No problem. Lift the hood and you should be able to find the fuse box in the left rear of the engine compartment. If you have trouble please take pictures or video and upload them in your response. Remove the lid to expose the tail light relay. Let me know what happens.
Feb 10, 2019 at 3:01 AM
FJKHAN24
  • 9 POSTS
Done that, what number is the relay?
Feb 10, 2019 at 3:17 AM
FJKHAN24
  • 9 POSTS
By the way, what fuse should I check also? please state the number correlated with the fuse.
Feb 10, 2019 at 3:19 AM
FJKHAN24
  • 9 POSTS
Got it, it was the #22 fuse 15 amp, which was blown. Thank you so much Ken for helping.
Feb 10, 2019 at 3:45 AM
  • 55,691 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Feb 11, 2019 at 1:58 AM
