Tail gate window not working properly
170,000 MILES • 0.6L • 6 CYL
TAMMY PHILLIPS
Can't roll window up or down but motor is good. can find white wire with green stripe,
Sep 27, 2019 at 9:17 AM
  • 55,694 POSTS
It sounds like a fuse or relay issue. here is a guide to help you check for power with the rear window wiring diagrams so you can see how the system works and which fuses and relays to test:
and
See where you are losing power. Check out the diagrams (below). Please let us know what you find. We are interested to see what it is.
Sep 29, 2019 at 4:24 AM
