Tag light brake light not working properly
233,000 MILES • 3.2L • 6 CYL • 4WD • AUTOMATIC
LEOLEO8
When I start my car listed above (Excel) I didn't turn on my headlights and I have no running brake lights or tag light.
Jan 2, 2021 at 7:14 AM
More then likely this is the smart junction box has failed but we need to test voltage coming out of it when the lights are supposed to be on. I am attaching the wiring diagram and here is a guide that will help with doing this testing:
https://youtu.be/Hlna_kUt7As
The SJB is more then a fuse block as it has a microprocessor on it and they are pretty common to cause issues like this.
Let us know what you find with this and we can go from there.
Jan 6, 2021 at 8:06 AM
