Tag light not working?
150,000 MILES
MROULET1
  • 79 POSTS
I noticed that my tag light was not working. I got new one's and still don’t work.
Apr 22, 2023 at 12:16 PM
  • 110,246 POSTS
Are all of the other tail lamps working, specifically the parking lamps? I ask because they get power from the same place.
If the other lamps are working, we need to check the connector for power at the license plate lamp.
At the light connector, probe the red wire to check for power. Do this with the lights on. (See pic below)
If there is power, confirm continuity to ground on the black wire. (See pic below)
joe
See pic below.
Apr 22, 2023 at 4:22 PM
MROULET1
  • 79 POSTS
Yes, all the other lights work.
Apr 23, 2023 at 12:14 AM
  • 110,246 POSTS
Okay, then we need to check to see if there is power to the light sockets as well as a ground. Are you able to perform the tests I mentioned above?
Apr 23, 2023 at 11:45 AM
