Tachometer, speedometer and radio cut off then car slowly shuts off
SCREMER69
  • 2000 HONDA CIVIC
  • 1.8L
  • 4 CYL
  • MANUAL
  • 160,000 MILES
I have a 2000 type R hatchback with a b16b1. I was driving to the store and I noticed my speedometer and tachometer went straight to 0, then the radio cut out and my lights went dim. When I pulled into the closest gas station the car shut off on me. I waited about 20 minutes adjusted battery cables and it started up fine, second I began pulling out same thing happened. Thought it was a ground but I don’t see any corrosion or damage, battery is charging overnight on my slow charger, if it’s not that, what besides the alternator could I be worried about?
Monday, May 25th, 2020 AT 8:39 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Yes, you should definitely test the alternator output.Here is a tutorial showing what is involved to test an alternator:
It should be charging the battery form 13.5-14.5 volts with car running. Do you have a meter to test? If not most local auto parts stores like AutoZone can test for free.Hope this helps and thanks for using 2CarPros.
Monday, May 25th, 2020 AT 3:48 PM
