Hi typerhunter,
Thank you for the donation.
Symptoms indicates a fault with the idling system and it mostly is caused by a dirty throttle body and Idle Air control valve.
Get them cleaned and if problem persists, get the valve clearance adjusted. If you are into DIY, get a can of carb cleaner and a piece of rag. Remove the air intake hose and spray some carb cleaner into the throttle body. Let it soak for a while and use the rag to scrub the internals of the throttle body, keepinig rag soaked with carb cleaner.
Starting might be difficult due to the presence of carb cleaner flooding the cylinders.
SPONSORED LINKS
Tuesday, September 22nd, 2009 AT 12:02 AM
