Stuck in 4 Low?
100,000 MILES • V8 • 4WD • AUTOMATIC
CAROLYNBAIN73
Is there a way to disengage the 4 Low manually?
Feb 21, 2023 at 6:13 AM
  • 55,676 POSTS
Yes, you can remove the transfer case shift actuator and move the shift shaft into position by using a flat blade screwdriver. Here is the location of the actuator so you can remove it. Here are instructions for the replacement in the images below. Please let me know how it goes.
Feb 22, 2023 at 11:24 AM
  • 110,248 POSTS
There are a few different transfer cases that were used based on the engine size, if it is a manual shift 4wd, or if it is an automatic 4wd.
Let me know. Also, let me know if what you have done so far. For example, have you checked the fluid level and condition in the transfer case? If it is a mechanical shift transfer case, did you check the linkage?
Let me know as much as you can.
Feb 22, 2023 at 11:27 AM
