Transfer case issues
125,000 MILES • 3.6L • 5 CYL • 4WD • AUTOMATIC
JULIOLOP
  • 18 POSTS
my car looks like activates the 4x4 by itself without press the buttons in the central console. Usually when going back and turn or when you try to make a U turn.
the T-Case can activate the actuator if it see any drag in one of the rear wheels?
all my problems came after some problems with the parking brake, activating by itself like two years ago. Last year, my front differential was rebuilt for that reason and it never stops doing it.
what can I do?
Jun 7, 2019 at 4:55 AM
SCGRANTURISMO
  • 4,897 POSTS
Who rebuilt your front differential and was there any kind of warranty extended for the quality of the repairs at that time?
Thanks,
Alex
2CarPros
Jun 9, 2019 at 6:11 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
I also forgot to ask you if your Malfunction Indicator Lamp (MIL) or "check engine" light is illuminated? If it is could you pull the Direct Trouble Code (DTC) for me. I have included a link below for you if you are unfamiliar with how to do this.
Please go through this guide, if necessary, and get back to us with what DTC(s) are present, if any.
Thanks,
Alex
2CarPros
Jun 9, 2019 at 6:26 PM
JULIOLOP
  • 18 POSTS
Hi Alex, thanks for your answer.
I think the AAMCO did the work like a year or more ago, the problem is the work was done in Sarasota and I'm in Miami.
I've visit some shops and they say the problem doesn't look like a differential problem, there is not any noise.
and yes just two or three times of many the Engine Light came up but just for a few minutes.
Can I still pull out any code DTC from the modules without the light?
Today I lost power in the front switches to close the doors. can it be a fuse?
BR
Jun 9, 2019 at 9:02 PM
SCGRANTURISMO
  • 4,897 POSTS
Is there an AAMCO in Sarasota? I believe that they honor each other's work as they are a chain of repair shops. You might want to check into that. If your MIL is not illuminated then there are no active DTCs to pull, so that's a good thing. I am not sure what you mean by the front switches to close your doors? I have rode in many Hummers, of course I was in the U.S. Army when I did, but the all had door handles to them. Does your 's have door handles too? Regardless, I would lean more towards a problem with the ground for the circuit. Fuses are there to protect an electrical circuit from a short to ground, so the circuit is cut before a fire from the infinite current flow happens (Ohm's Law). Please get back to us about the switches and we will go from there.
Thanks,
Alex
2CarPros
Jun 10, 2019 at 2:21 AM
JULIOLOP
  • 18 POSTS
the harness were removed from the main switch in the driver's door and everything working fine now after put them back
I have several questions...
1.- the 4x4 can activate itself and automatically?
2.- what if one of the wheels is hardest than normal?
3.- why for is the speed sensor in the Tcase?
4.- and the decoder motor can be damaged?
sorry but I'm trying to understand how the system works, before focus in the TCase replacement, is it true the car has to be reprogrammed if I change de TCase?
BR
Jun 10, 2019 at 9:06 AM
  • 55,588 POSTS
If the switch goes bad it will self activate. I would replace it first, the encoder will not operate unless the switch activates. Check out the diagrams (below). Please let us know what you find. We are interested to see what it is.
Jun 12, 2019 at 9:54 AM
JULIOLOP
  • 18 POSTS
when I place the truck in neutral and activate the switches, everything looks normal, lights change and everything, you can hear the transfer case changing and making the same sound
when the failure occurs the light 4WD unlocked remain lit.
why do you suspect of the switch?
I've been reading a lot about transfer case and everything related lately,
the problem looks to me below, the 4WD engage without command and according to what I read, it can be caused for a defective VSS, or defective encoder, or definitely a bad TCase (folk) or other thing inside.
I also suspected the TCC module but I have inclination to think if the module is defective the lights should be changing, don't you think?
this is my plan.
1.- I will change the sensor,
2.- I will change the encoder if nothing happen
3.- I will have face the TCase replacement
one last question, any of these changes will require any programming....?
I will keep you posted...
Jun 12, 2019 at 10:57 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Okay, here is everything that there is to know about your vehicle's Transfer Case. The best part about the information that I included in the diagrams down below for you, is that this information isn't hype or speculation, but a description of how the component and related sub components work and work together from the vehicle manufacturer themselves. No guessing or misinformation here. Please go through this information and get back to us with what you find out.
Thanks,
Alex
2CarPros
Jun 12, 2019 at 5:30 PM
JULIOLOP
  • 18 POSTS
Sure, I have this complete manual.
Thanks
Jun 12, 2019 at 8:21 PM
JULIOLOP
  • 18 POSTS
I have a risen question.
in case that I need to replace the encoder motor, what if it is in a different position than the T-Case?
can I connect it to the harness and start on the truck without to hook it up to the T-Case ?
BR
Jun 13, 2019 at 3:21 AM
  • 55,588 POSTS
Yes, you can match the encoder motor position before installing it. That way when installed you can use the switch to check it to the desired position.
Jun 14, 2019 at 4:19 AM
JULIOLOP
  • 18 POSTS
Two questions
Do I have to drain the TCase before the encoder replacement?
Jun 14, 2019 at 5:48 AM
JULIOLOP
  • 18 POSTS
When I switch from 4WD to 4WDHi lock I can’t hear anything being in neutral and with the door open
Going back to 4WD I do can listen a little noise
When I go for and back to 4WD Lo lock I can listen a bigger noise
Jun 14, 2019 at 5:53 AM
JULIOLOP
  • 18 POSTS
the 4x4 activates by itself if one of your rear wheels is getting hard to rotate than the other one?
Jun 17, 2019 at 1:31 AM
  • 55,588 POSTS
Sorry for the slow response busy weekend. Can you please shoot a quick video with your phone so we can see what's going on, that would be great. You can upload it here with your response.
Jun 17, 2019 at 3:51 AM
JULIOLOP
  • 18 POSTS
I've not proceed because I was told after you replace the encoder motor or the transfer case you need to reprogram the modules. is that true?
Jun 25, 2019 at 12:48 AM
  • 55,588 POSTS
I don't think so. here are the instructions on how to replace the encoder I don't see any relearn notes. Check out the diagrams (below). Please let us know what happens.
Jun 25, 2019 at 4:54 AM
JULIOLOP
  • 18 POSTS
okay, transfer case down, open and verified defective plastic fork (replaced).
my concern now is how to put back the piece that move the fork, any suggestion or it is easy?
Jul 18, 2019 at 10:16 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Okay, In the diagrams down below I have included the entire directions from the vehicle manufacturer for the assembly of your vehicle's transfer case. Please go through this guide and get back to us with how everything goes reassembling it.
Thanks,
Alex
2CarPros
Jul 18, 2019 at 11:41 PM
JULIOLOP
  • 18 POSTS
Alex, thanks for your prompt answer.
do you have all this in just one PDF?
now I have several doubts.
I can see nothing related to the shaft I asked, the one that is moved by the encoder, and in the planetary I only have marks in two gears, is it okay?
Jul 19, 2019 at 2:01 AM
  • 55,588 POSTS
sounds right can you upload a picture of what you are talking about?
Jul 22, 2019 at 4:19 AM
JULIOLOP
  • 18 POSTS
to place the sprocket inside that planetary gears assy you can see in the picture on top of the chain has been very difficult
following the manual you have marks in the four upper gears,
Jul 22, 2019 at 5:11 AM
  • 55,588 POSTS
Sorry, I am not sure what you are saying, there is no timing for these gears, can you be more specific, what is the problem ?
Jul 23, 2019 at 5:08 AM
JULIOLOP
  • 18 POSTS
Okay Ken,
Work is done and it looks okay.
the plastic fork was replaced by aluminum fork.
the H3 drive smooth like months before, while it was parked I replaced my sparks and cleaned up the throttle body.
the thing I noted now is around 30-35 miles the car starts to shake, what can it be?
Aug 12, 2019 at 9:33 PM
  • 55,588 POSTS
Yep, the plastic wears out not engaging the transfer case. Did the shake start after the transfer case repair or was it there before? if after I would look to see if the driveshaft is stalled correctly you could have a balance issue. Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Aug 13, 2019 at 2:54 AM
JULIOLOP
  • 18 POSTS
After the transfer case installed balance? please, don't scare me, what is the driveshaft? is it inside the TC or external? I placed everything back as installed before.
I will take the video after living this place this place.
Aug 13, 2019 at 3:44 AM
JULIOLOP
  • 18 POSTS
no need for videos, and yes, you were absolutely right.
I got both driveshaft checked and noted one of them was a little out of position, so now it's working fine, no more vibrations.
Aug 13, 2019 at 9:06 PM
  • 55,588 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Aug 14, 2019 at 3:03 AM
BEEILLY
How can I tell if the plastic fork in my transfer case in my 2006 Hummer H3 is going bad. I have not had any adverse effects, would not mind getting it replaced or machining me a new one. I have alot of experience working on vehicles. It drives around good, I have just heard alot about this part. My father is a GM certified mechanic, I asked him and he told me that if it has no adverse effects then he would not help me pull the transfer case apart. I really dont know how to tell if it is bad.
Aug 14, 2019 at 3:04 AM (Merged)
RIVERMIKERAT
  • 6,106 POSTS
Does it work? No? It's bad. Yes? It's good. If I'm interpreting your father correctly, he doesn't want to dig into a fairly major job like if there is no problem.
RIVERMIKERAT
  • 6,106 POSTS
In other words: "If it ain't broke, don't `fix' it."
JULIOLOP
  • 18 POSTS
Ken
I have one issue
the car always drive smooth but randomly gets stuck when you move in reverse for example trying to go out of a parking spot.
I think it's something with the parking brake probably, you can here a noise, like a squeal
what do you think??
Aug 15, 2019 at 10:40 AM
  • 55,588 POSTS
Please post your new question here, you must be logged in.
Can you please shoot a quick video with your phone so we can hear the noise? that would be great. You can upload it here with your response.
Cheers, Ken
Aug 16, 2019 at 4:11 AM
