Synthetic Oil and conventional oil mix
1999 CHEVROLET S-10
45,000 MILES • 3.2L • 6 CYL • 2WD • AUTOMATIC
RWEST747
had a full synthetic oil change done, and then my wife topped off with half a quart of conventional oil recently.
Is there a major issue with this, and do I need to drain and refill with synthetic to purge out the conventional, or is this not a problem?
Feb 18, 2015 at 3:41 PM
HMAC300
  • 48,601 POSTS
no just run it like that until you have to add oil or next oil change. there is semi synthetic on the market which is 25% synthetic oil. you may see your oil go a little faster than normal however due to the mineral oil your wife added. won't hurt it abit.
Feb 18, 2015 at 3:51 PM
