Synthetic oil
2014 DODGE CARAVAN
30,000 MILES • 3.6L • 6 CYL • FWD • AUTOMATIC
PAPET
  • 105 POSTS
I just want to ask about the benefits of using a synthetic oil. For the past years, I have been using regular oil and I am planning of switching to synthetic oil. And how often do I have to change synthetic oil? I am driving 20 kms everyday. Thank you very much and hoping for your most appreciated reply.
Jan 19, 2016 at 8:33 PM
PACO8224
  • 117 POSTS
Synthetic oil provide better performance to your enegine giving it more life. It works so much better on high temperature then conventional oil. Can't go wrong with switching. Every 5,000 miles is the best time to have oil change with synthetic
Jan 19, 2016 at 9:27 PM
WRENCHTECH
  • 20,761 POSTS
You can go further on the interval than that. Some manufacturers recommend as much as 15,000 miles with full synthetic but personally I wouldn't go over 8,000.
Jan 19, 2016 at 10:36 PM
PAPET
  • 105 POSTS
Thanks for your most appreciated replies gentlemen. After switching to full synthetic oil, I think it is better to go every 5,000 kms especially I drive everyday.
Jan 20, 2016 at 1:37 AM
WRENCHTECH
  • 20,761 POSTS
5,000km is only 3,000 miles and you can safely get much more than that with full synthetic oil. I would recommend 8,000 miles which is about 10,000km
Jan 20, 2016 at 1:50 AM
PAPET
  • 105 POSTS
Ok I will do that then and once again thank you so much for the info.
Jan 20, 2016 at 1:59 AM
