Sync 4 removal?
12,000 MILES • 4WD • AUTOMATIC
COOKEE
  • 20 POSTS
Need to removal the Sync system from a 2025 ford explorer. Heard it was behind the center stack. Looking for removal instructions.
Thanks
Aug 15, 2025 at 12:04 AM
  • 55,649 POSTS
I am not suer what you mean by "sync" but here is how to remove the info screen. Check out the images (below). Please upload pictures or videos in your response so I can see wat you are talking about, also please respond to your older posts so we can close them out.
Aug 15, 2025 at 11:29 AM
COOKEE
  • 20 POSTS
The (Sync 4 APIM module) thats located behind the the climate control
Aug 15, 2025 at 11:37 AM
COOKEE
  • 20 POSTS
Sync 4 module
Aug 15, 2025 at 11:42 AM
  • 55,649 POSTS
Gotcha, the APIM sits directly behind the touchscreen and HVAC controls. Check out the images (below). Let us know if you need anything else.
Aug 15, 2025 at 11:50 AM
COOKEE
  • 20 POSTS
The brake down you sent me, is that for the 2025 model? I think one sent me a later model.. just make sure.
Aug 15, 2025 at 12:04 PM
  • 55,649 POSTS
Yep, it was for a 2024, I did more digging and found the SYNC module, it is at the left side of the dash, here is a diagram that shows its location. You dont need to remove the screen. Check out the images (below). Let us know if you need anything else.
Aug 16, 2025 at 1:57 AM
COOKEE
  • 20 POSTS
Thanks for going extra mile. I appreciate you
Thanks.
Aug 16, 2025 at 2:43 AM
  • 55,649 POSTS
You are welcome, come back anytime :)
Aug 16, 2025 at 12:24 PM
COOKEE
  • 20 POSTS
Hey do need to in another request. Im looking for that same Sync 4 apim model in a 2024 Lincoln novelist..
Let me know..
Aug 18, 2025 at 2:05 AM
  • 55,649 POSTS
No problem, I can help but you will need to start a new thread. You must be logged in.
Cheers, Ken
Aug 18, 2025 at 3:56 AM
COOKEE
  • 20 POSTS
Sent it..
Thanks ken..
Aug 18, 2025 at 4:21 AM
  • 55,649 POSTS
You are welcome :)
Aug 18, 2025 at 5:07 AM
