Sway bar torque specs needed
194,394 MILES • 3.8L • V6 • 2WD • AUTOMATIC
CHRIS KINARD
  • 97 POSTS
Torque specs on the sway bar bushings.
Mar 11, 2020 at 8:21 PM
CHRIS KINARD
  • 97 POSTS
And should I replace the inner and outer tie rods or can I just replace the outer tie rod?
Mar 11, 2020 at 8:40 PM
MOTOR MASTER
  • 279 POSTS
Hello my name is Dave.
As far as the tie rod ends; yes, you can replace just the outer ones provided they are the ones showing play, the inner usually outlast the outer by a considerable amount of time/use.
For your sway bar the bushings torque is 52 lb/ft and the links are 14 lb/ft
Let us know if we can help you anymore and thank you for using 2CarPros!
Mar 11, 2020 at 8:55 PM
Good morning,
I posted the spec for you for the sway bar bushings.
Also, you can just replace the outer tie rod ends without doing the inner.
https://www.2carpros.com/articles/tie-rod-end-replacement
Mar 11, 2020 at 9:00 PM
CHRIS KINARD
  • 97 POSTS
Thanks a lot guys heck ya!!!!! God bless.
Mar 11, 2020 at 9:13 PM
You are welcome.
Always glad to help.
Mar 11, 2020 at 9:15 PM
CHRIS KINARD
  • 97 POSTS
And the inner tie rod torque specs please.
Mar 11, 2020 at 10:22 PM
Attached.
41 pounds.
Mar 11, 2020 at 10:26 PM
CHRIS KINARD
  • 97 POSTS
And going to install a ball joint on the lower control arm. anything I need to know and what are the torque specs?
Mar 12, 2020 at 8:17 PM
Good morning,
Torque spec attached.
Mar 12, 2020 at 8:20 PM
