swapping engines
120,000 MILES • 5.9L • V8 • 4WD • AUTOMATIC
FLANDY
I installed a 1997 360 with transmission as one, but not computer. Truck fuel pump runs but no spark. Computer not communicating. Replaced plugs wires, points, distributor.
Oct 20, 2016 at 5:49 PM
HMAC300
  • 48,601 POSTS
try resetting security system if no owners manual look on line if link does not work.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Oct 20, 2016 at 11:48 PM
  • 55,512 POSTS
Hey FLANDY,
Check all system grounds the computer should communicate. Also check all fuses if you have not all ready. Also try the scanner on another car to make sure it is working.
Let me know what you find so we can continue.
Best, Ken
Oct 21, 2016 at 3:34 AM
FLANDY
My truck is locked in shop until Monday. I am trying to find the wiring schematics of engine to follow completely. Will try the resetting security first. The scanner works fine. Is the computer even compatible? Will also be trying my sons computer-same size and year as I put in. Thank you for helping me. mechanic and owner at shop gave up (it has sat now near a month).
Oct 22, 2016 at 4:48 PM
  • 55,512 POSTS
It will be difficult to say if the computer is the same only the architects at Dodge could tell you that, the best best when you do an engine swap is to get the computer and harness from the car you are swapping the engine from. Here is the wiring diagrams.
Please let us know what you find so it will help others.
Best, Ken
Oct 24, 2016 at 2:00 AM
