Swap out instrument cluster
179,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
REO3
I would like to swap out my 1990 "Moonie" cluster for one of a compatible year model 1988 - 1993 I think. I want to replace with regular analog needle gauges. Is this just a plug in the doner cluster, and it works proposition?
Nov 13, 2018 at 1:05 AM
JONNYB1963
  • 263 POSTS
I have heard more and more people interested in doing this lately. This might not be a simple plug-n-play affair. Your vehicle is right on the cusp of when they changed things up.
Can you upload a picture of the back of your cluster? It may be possible that a 1991 needle gauge cluster may work depending on the connector.
Jon
Nov 13, 2018 at 1:44 AM
REO3
Thanks Jon, I do not have this cluster out right now but will in a couple of weeks at the longest. I have had them out in other similar GM trucks.
I will get some pictures then and post them. I just acquired this truck and I am in the ordering and gathering parts that need replaced etc., process. So, I can keep from having a "parts laying everywhere that I forgot where they went" disaster. Thanks again, Steve
Nov 13, 2018 at 9:04 AM
JONNYB1963
  • 263 POSTS
Okay. let us know when you get to that point. Hopefully it will work out. It may require that you look for a certain vin code in the donor vehicle.
Jon
Nov 13, 2018 at 11:04 PM
REO3
Thanks, I have a good prospect for a doner, It is a running 1994 C1500 with a lot of new parts and new tires. Going to get it for $600.00 so I cannot go wrong. It just has a ruined interior, (seats and carpet),and the door hinges are either broke or the pins are trashed. Going to go look it over real good this Saturday and pay the guy. He is just tired of the wife giving him crap about it! -Steve
Nov 14, 2018 at 7:27 AM
  • 55,554 POSTS
It sounds like you have a good prospect for the project. Let us know if you need wiring diagrams to confirm the swap.
Nov 16, 2018 at 11:49 AM
REO3
Thanks, how do you feel about the schematics offered in the Haynes or Chilton manual? I can read a schematic, (trained e tech, USAF, from the 1970's analog years, but not 100% ignorant of digital).
Nov 17, 2018 at 12:11 AM
  • 55,554 POSTS
Here are the wiring diagrams for the instrument cluster so you can confirm the locations and connections. This guide can help you as well.
Cheers, Ken
Nov 17, 2018 at 1:56 AM
