Can I use a 2010 Charger differential in my car listed above?
Mar 19, 2018 at 3:10 PM
✓Experienced Mechanic
The ratio will be stamped on the crown wheel or on a tag on the differential. check that it is the same.
Mar 19, 2018 at 5:32 PM
LARRY1980
MEMBER
Everything bolted right up but the spindle for the drive shaft would not. so can I use the spindle off the old differential?
Mar 19, 2018 at 10:10 PM
PATENTED_REPAIR_PRO
What are you referring to as a spindle?
Do you mean the flange on the front of the differential that the rear end of the driveshaft bolts to? #2 shown here?
Does that #1 coupler unbolt from the end of the driveshaft?
Image (Click to enlarge)
Mar 20, 2018 at 1:53 AM
LARRY1980
MEMBER
Yes, the flange on the differential.
Mar 20, 2018 at 1:55 AM
PATENTED_REPAIR_PRO
Does the coupler unbolt?
Mar 20, 2018 at 1:58 AM
LARRY1980
MEMBER
Yes.
Mar 20, 2018 at 5:40 AM
PATENTED_REPAIR_PRO
Okay, does the coupler from the other driveshaft fit on this one? If you do not have it you may want to check if it will fit on this driveshaft because you know it will fit to the differential flange.
Mar 20, 2018 at 6:34 AM
LARRY1980
MEMBER
I have it but it does not fit the drive shaft.
Mar 20, 2018 at 6:36 AM
PATENTED_REPAIR_PRO
You may want to check near you for a driveshaft shop that can help you fix this problem. perhaps they could cut off and weld the end of the driveshaft that this coupler does fit the flange onto the driveshaft that fits this vehicle. Did you by chance just check if the entire driveshaft from the 2010 would fit? Or if it is a two piece if just the back half would fit?
